Garage ceiling/bedroom floor insulation?
StickyRust
PA
I have an attached, unheated, 2 car garage with 2x8 joists. Above the garage are 3 bedrooms and 2 bathrooms. I just finished removing ~R13 fiberglass and OSB from the garage ceiling.
I have decided to reinsulate with Rockwool.
Option #1:
1.5" EPS(that I have extra of) right up against the subfloor, caulked, then R23 5.5" Rockwool
R28.75 total insulation
Option #2:
Just install R30 7.25" Rockwool
I really do not want to use drywall, can I perhaps just use plywood because i am using Rockwool?
Thanks!
e36jon
San Francisco CA
Out here code for garage ceilings with occupancy above is two layers of 5/8 drywall, plus a bunch of detail stuff around penetrations and such, all in the name of fire safety.
I am also using rock-wool in my similar situation for both added fire safety and better sound suppression that fiberglass. That said, by the time rock-wool is showing off it's superior fire resistance I would say the game is already lost...
StickyRust
PA
yeah, so the drywall is just if I want to comply with code that hasn't been in compliance for 40 some years :bounce:
so my only question is the foam + rockwool or just rockwool
PCustoms
VT
Foam, if edge sealed with canned foam, can air seal and reduce fumes and air exchange.
But don't be a cheapskate, whatever you do use 5/8 rock to bring it to code.
StickyRust
PA
i.imgur.***/i04jEnh.png
It wont let me link, but replace the .*** with .com to see what I was going for
the plywood I want to use will actually be more expensive than sheetrock, i just have no desire to deal with sheetrock
PCustoms
VT
Yes, if you foam seal the rigid foam and then use glass or roxull you get better performance.
The 5/8 sheetrock is about fire code and life safety. Do it right.
Kaizen
New England
Using roxul should be good with air sealing. If you have water pipes up there I’d insulate all of those with rubber insulation as well.
pvanderlugt
^^^^^... This is good info from the fire chief.... I would take his advice... like the commercial says, he has probably seen a thing or 2...
