My garage is 24 x 24 with a double garage door - ok size for me. The house was built in the early 80s and the exterior walls are brick veneer. I assume the walls are insulated however I have not confirmed that.
The attic over the garage is not insulated and there is tongue and groove subflooring on the attic floor. I do not use the attic for storage and I'm positive I will never use it for storage. There is a pull down staircase for access if necessary.
I want to insulate the attic so I can get some use of the garage in the winter time - however I'm not sure the best way to insulate. Should I remove the decking from the attic floor and insulate? Should I blow in insulation? Is it ok to roll out insulation over the top of the decking?
I don't necessarily want to remove the decking - but will if necessary.
thanks for the suggestions....
