First off, kudo's to you for keeping the looks in line with the house.....your neighbors will be happy....and you will be happy when and if you ever go to sell it....
Thanks! We have a wide variety of house styles in our neighbourhood and I really want this garage to look like it was built when the house was.
Did you post a thread awhile back about trying to reuse the wood from your old garage? That garage is staying after you build this one?
No, that wasn't me. I plan to keep the small garage for extra storage.
I'm in the process of building a 20' x 25' garage now....basic structure is done including the roof....as soon as I get back home, finish up some details and get my rough inspection done....hence, I have a few things you want to take into consideration....
Go as big as you can. I think 20' is a good width and compromise when dealing with the construction details....go longer if possible....
Sadly I'm limited to 20 x 26. I have 28' between the house and the property line, and I have to be 4' from both. I can't go any deeper due to the way the house is built.
On the upstairs dormers, make them as large as you can....you will be glad for the extra space.....they make a great place to put a bench so you can look out the window.
That's a good idea, but the upstairs will be mainly for storage of parts. The only real reason I added the dormers were for curbside appeal and to get some natural light up there.
Positon - where I am, my height was restricted by how close I was to the property line. To be over 15', I had to be at least 5' from all property lines. So, I kept mine to 15' and I'm 6" from my west line and 2' from back.....I suspect you will have the same issue....so take into consideration what you want to do with the dead space that you will have to the side and back.....
I will have to get a variance from the town to build the height that I want. We're limited to 12' to the peak, but I should have no problems getting the variance to go 20'.
Garage door - Like Steve said, you might want to consider going bigger.....but that could change depending on what you do with the existing garage. What is the bottom going to be used for? And, have you considered a Carriage door? Considering the look you are going for, it could really set off the look of the garage.
I may go with carriage doors, I think they would look perfect. The main floor of the garage will be used as a workshop for building & maintaining my hotrod and future projects. I've never had a garage to actually "park" in, so I have no issue with leaving the daily drivers outside. I've always heald the belief that garages are for working in, not for parking.
Have you considered a spiral stair case instead of regular stairs? The reason I suggest that is because regular stairs eat up a lot of floor space top and bottom....and once again, considering the look you are going for, it would be a nice touch. I have one in my garage...it's only 4' 6" in dia (24" tread width) but I'm very pleased with it....room enough to carry a standard plastic tub up....and the kids don't go racing up and down it....I have a trap door in front of it for larger items that need to go up or down.
I gave a spiral staircase some thought, but I prefer a regular set of stairs. It will take up some floor space, but it also leaves plenty of "under the stairs" storage for welders, etc. It's a bit of a trade-off.
Boyd......I feel your excitement.....it's going to be fun.....and stressful.....wait until you start the permit process.......he he....
