I just finished the last pour on a 3.5 story ICF house with a 3 car garage at the very bottom. We have 8" and 6 1/4" walls over various bays and were able to build the bucks with plywood and vertical supports under that.
I assume the jambs you have put up are temporary and will be removed once the pour has cured? Or are you skipping a reinforced lintel and using the 2X12 to hold up the wall above?
The thing with ICF is that its a ***** to change in the future... For something like this, I'd build the opening square and then frame the arches out afterwards. Once the siding is on, you'll never know the difference and the framed arches will give future owners options on changing things up. (It will also be easier to pour.) We are doing this with one of our bays. We have poured it at 11' and are framing it down to 8'. (Our local code requires a commercial fire rating on the garage if any doors are over 8') If I need a bigger bay in the future, I can remove the framing and add more fireproofing to the garage interior.
We have a circular window and are doing the same thing - pouring the opening square and then framing it in for a circle. The architect first said the circle window was wonderful. Then, last week, they said they hated it and wanted to go square. The window was already ordered, but I was really glad we poured the opening square.
If you want to pour the opening in an actual arch, making the buck is not the hardest part. I'd make an arch out of 2X, cover the top with a build up and laminate (with liquid nails) several layers of 1/4" ply on top of that, and then fill the cavity with a build up of several thin layers of foam. (So you can curve the foam with out breaking it.) The 2X can be braced vertically with 2X6's from the sill. The catch with this is the reinforcing... If you have a straight lintel reinforcing detail up above, the edges of the arch that poke down will be weak. You'd need to reinforce these sections with a some curved rebar or other method. (I'd probably consult an engineer for a reinforcing detail like this.)
Did I mention that you might want to pour square and frame in the arch???
