Garage door awning question
Jbmotorsports
Garage is finally at the point where I can add the awning over the doors. It was going to be around 36" angled down and around 22' wide with exposed rafters and will be metal roofed. A coworker was going to help me build it and is trying to convince me to not do exposed rafters because of the maintenance that will be involved: painting, animals nesting in it etc. I believe those to be valid points but I really like seeing the rafter tips poking out at the end like the attached picture. I'm a little torn so looking for some guidance from those with more experience
Metallitubby
ATL OTP North
I did exposed rafter tails on my new house. I cannot speak to the maintenance yet, but the wasps/hornets are loving the new opportunities already. Keep a good can of wasp killer around if you do. Otherwise, it looks great!
bradpac
Central TX
Around here wasps, hornets, etc will build a nest on the eave overhangs, brick ledges, soffits, whatever they can find. If you like exposed rafters do exposed rafters, a good coat of paint lasts years and a spray down with a water hose every so often keeps it looking good.
J
Jbmotorsports
Yeah, we already have wasp and hornets but they aren't aggressive and I can just spray them. Ok, I know it didn't take much, but it's what I really want so I should just do it. Then in 5+ years I can complain about how I shouldn't have
Stuart in MN
Minneapolis
As long as the rafter tips don't stick out beyond the roof it should be okay. It's a little more work to paint, but under cover like that the paint should last a long time.
CraigStu
Blacksburg, Va
Look at it a bit and do things in such a way that it would be relatively easy to close in. I am thinking make the ends of the rafters long enough to see but recessed enough that you could cap the ends w/ a pvc trim board and still have enough overhang of the metal roofing. I don't remember what the named purpose of the PVC board I looked at the other day was but they were only about 3/8 thick. So a 3/8 x6 capping the rafter ends and then put plastic soffit on the bottom of them. Usually soffit or other ceiling under a porch is done horizontal but I have seen some where the soffit is attached right to the underside of the rafters and it looks fine.
dfiler2
NW Minnesota
I would do like CraigStu suggested, if it gets to be a problem, enclose it. It will probably depend a little on which way it's facing and if there is other shade as to whether bird nests or wasps are an issue.
J
Jbmotorsports
Thats exactly what I was thinking. I'm in southeast PA so it's not exactly ideal but i believe the way its constructed leaves the possibility of enclosing if issues arise. I thought about pvc caps for the tips but can't really figure out how that would work. Maybe thing composite board mitre cut to form caps. I appreciate all your guys' input as I have no one to really bounce these ideas off
ace10
Rural NoVA
Carpenter bees, above ground stinging insects and birds will all appreciate the housing opportunity.
CraigStu
Blacksburg, Va
Sorry that I used the wrong term. What I was thinking of when I said cap the ends is properly referred to as the facia.
My thinking is that the thickness of the facia board determines how much overhang you need of the roof material beyond the ends of the rafters. So, if you build in a little extra overhang beyond the amount you need w/ just rafters, you could later, if needed, attach a facia board to begin closing in your awning. That 3/8 thick board I mentioned would need less overhang than the more typical 2x6 or 1x6 facia.
J
Jbmotorsports
I was thinking the same thing. Maybe have it so that if I needed or wanted to enclose it later I would be able to do so without major overhaul. Thanks guys!
