frankd
I need to replace the bottom seal on my current garage door and I'm having trouble finding a suitable replacement. The door is metal, 16 feet wide and 1 7/16 thick. There are no channels to mount a new seal. The current seal is rubber/plastic and is screwed to the bottom of the door with what appear to be sheet metal screws. It looks like there is a recessed channel along the center of the bottom of the door, and that's where the current seal is attached.
I was going to go with a replacement kit on (see link below) but just realized that the bottom of my door is not flat. The front part of the door (facing the driveway) has a small metal lip that comes down about 1/8 of an inch. So If I install the replacement kit that I linked below, it wont sit flat/level.
I searched for other options but all I could find is this generic foam rubber seal (which might be fine).
Hopefully you guys will have some better suggestions.
Replacement kit:
https://www.acehardware.com/departm...rganic-shopping&utm_campaign=organic-shopping
Generic cheap rubber seal:
https://www.acehardware.com/departm...ripping/weather-stripping/5436704?store=16280
Replacement kit:
