Garage door bottom track for seal
diego1236
How safe is it to remove garage door track and replace it with a new one mines broken and has old seal i can't get out thanks!!
mike93lx
Richmond, VA
We aren't seeing pics. The track that holds the bottom seal is fine to remove. What is making you concerned about safety?
D
diego1236
This part photo having issues to send
D
diego1236
Just checking not sure if it'll mess up cause I think there's a wire attached next to it so should I be good?
PCustoms
VT
Do not remove that!
This will IMMEDIATELY release spring tension and likely injure you or break something. Those red screws are red to note DANGER.
I don't think you have to remove that to change the seal anyway. Open the door and look up at the seal, it should be clear. If not, call a professional.
