Hollywood D
Hey, first post. Have a question about garage door bracing. My truck is about 1" too long to fit in the garage. If I was able to remove the bottom piece of bracing from the door and replace it with a piece of lumber I would have clearance. The door has the standard metal u-channel braces. It's a 2-car garage, 7' x 16' door I believe.
I searched everywhere and cannot find anywhere where someone has used wooden bracing on a garage door, which makes me believe it can't be done. Not sure if the lumber would be able to withstand the forces. I was thinking a piece of 1x4x16. The door is a wooden/particle board door (or whatever it is they use now).
I suppose I could also 'push' the door out a little bit by removing the trim and adjusting the tracks out. Not sure what else is involved in that though to do it correctly.
A standard 2x4 is only 11/2" thick. That's a reinforcement strut, what would you fasten it to?
