cstmg8
I've read a few threads on here regarding this situation, but none that are at the point I'm at.
I've installed the doors:
10x10 insulated with one panel of windows
Standard rise but immediately following the trusses.
Two springs per door.
I have high lift drums on them.
With the sprigs wound, the doors will spring open at full close, and will not lift much over half way.
What is my fix? I'm putting in jack shaft openers, are they strong enough to overcome this in both directions?? My current springs can't be adjusted to work correctly and hold the doors up.
I'll probably call a local professional, but is there an easy fix for this??
