teamextreme
I've searched and found some on-line calculators for beam sizing but since I don't know modulus of elasticity values, and it's been way too long since I took that one strength of materials class, so they aren't helping me much. Hopefully someone here can help me out in sizing a new header beam.
My door is 84" tall (four 24" panels) but I want it taller to get my truck with camper in. It needs to be minimum 99" to work, which means I need to gain 15" of room. As you can see from the pics, above the door is a 11.75" x 3.5" header (non-LVL, no metal sandwich, just 2 2x12's), then 9" of free space, then a two 2x4 top plate. If I eliminate the 9" of free space and can replace the existing 12" header with a 6" steel I-beam I can get the 15" I need without having to do anything crazy like raising the roof which I thought I'd have to do.
What size steel I-beam would be required? I know a 6" I-beam runs through my basement and supports the whole house, so I would imagine it should work for the garage door header. Garage is detached, 30 ft x 23 ft with gable end on short dimension. Door is 16 ft wide.
