Garage door hinges
NUTTSGT
Northern Central Ohio
Re: Where can I find these garage door hinges?
A quick look at Lowes, HD and Menard's website doesn't show them. However, a trip to the store and knowing what brand the door is and the size, they maybe able to order them directly for you...same goes for a local garage door guy.
gnpenning
I have more questions than answers.
Pieces of craps. That's what low bid looks like.
If the door manufacturer ran a proper stile you can use a real door hinge just using Tec screws to attach. Doing so may leave some of the old holes visible. New ones should cover the holes??. If your OCD is stronger than your need to upgrade then get the old hinges.
Stuart in MN
Minneapolis
Anyone know what these would be called.
From the link above this looks like it should work but you'd have to drill some new holes for the screws:
https://ddmgaragedoors.com/parts/part/HI-1400C-WD.html
joes169
WI
I help a friend occassionally with his OH door business. Those are the center hinges used on residential Wayne Dalton doors. I've puts dozens (probably even hundreds) of those exact hinges on in the last few weeks. Try to find a locasl Wayne Daulton supplier.
Mopar_Ray
The ones with 6 holes or the ones with 4 holes like I’m looking for?
why worry
Mcmaster carr sells various sizes of Piano Hinge. Then you cut to length
Dave
joes169
WI
The 4 holes that you posted.
If you can wait, I'll be helping install 2 residential doors on Thursday, I can double check then.
