Garage Door Install
Cudajas
Cambridge Ontario Canada
I need to replace my garage door (single) due to some accident damage (long story). No its not fixable.
I am toying with the idea of doing the install myself in order to try and save a few bucks. Really just need to replace the door itself, the spring etc. all look ok.
I am pretty handy, and it looks pretty straight forward, but what do you guys think...is this something that a DIY kind of guy can handle.
Jason
Crazyjake8493
Upstate NY
Re: Garage Door Instal
I think it's definitely a DIY job. I have one I've been looking to replace on the back of my garage, but it's not a high priority so it's been sitting in the garage for now.
There's a couple episodes of Ask This Old House where Tom goes through the steps of replacing one with a homeowner..
Edit: I've never worked on a door with a torsion bar/spring, so that may be out of the scope of a DIY'er. I'm not sure. But for a door with regular springs it shouldn't be too difficult.
homebuilt burner
central Wisconsin
I did mine with my 16 year old assisting. Not to tough, be careful with the torsion springs. A lot of people will say just hire it done but I figured I saved $200, it took @3 hours, I think that is pretty good wages. Read up watch a couple videos you should be ok.
BillK
Beautiful Southern Maryland
Jason,
I have done two. On was a new install when I built my detached garage and the second when I replaced the door on my attached garage. Both were 16x8 doors. No problems with either one including adjusting the torsion springs. I did it mainly to make sure it was done properly :)
This guys site has a lot of good info and videos: http://ddmgaragedoors.com/diy-instructions/replace-garage-door-torsion-springs.php
PassnThru
Bowling Green KY
Jason
Make sure you have proper winding bars - not just whatever you have laying around.
I understand - I had to replace the bottom two sections on one of my doors one time due to an 'accident'. I didn't own that 'accident' but I owned the fix.
Funny how it works that way :lol_hitti
493 scamp
Kirkwood,Illinois
Easy to do as a DIY project. I used the easy set spring winder style, just adjust with a socket and ratchet.
p-1444433944150-c-7577.htm
Chris705
The Finger Lakes of NY
I purchased a replacement OH door at lowes or HD and followed the instructions that came with it. I was careful when winding the torsion spring and followed the instructions, it's been 5 - 6 years and all is well. My old wood door rotted on the bottom rail. Wasn't a difficult install, I just followed along and crossed off steps along the way to make sure I didn't miss anything.
matt_i
I think its easily doable with the instructions. It will take longer than the pro installers.
I have done one [Haas] and modified another track/cable setup.
C
Cudajas
Hey folks,
I realize this is a little over due, but I did finally get my garage door installed.
I decided to do it myself and I certainly glad that I did.
The install went fairly smooth...except that I installed the spring backwards. Fixed that and it worked like a dream.
The only difficult part is unwinding and winding the spring (well and maybe reading the instructions). I used some 1/2 inch round stock to make two winding bars, and while it takes some effort and I can see how it could be dangerous, if you take your time and are aware of what you are doing, its really not that difficult.
Another project crossed off the list.
rwhite692
Central Valley, CA
Hey folks,
Good job! As they say, it ain't Rocket Surgery!
PassnThru
Bowling Green KY
Good deal! Thanks for checking back in.
Those springs do require some effort at the end don't they :lol:
That's why good winding bars are important. At this point, I think I've messed with those springs about a half a dozen times. I recall the first time I did it - my tools consisted of a punch and a big Phillips screwdriver :eek:
The second time, I also purchased round stock and made some winding bars.
