Garage door insulation kits
JackOfDiamonds
Idaho (USA)
Has anyone used a garage door insulation kit that they like?
I'm worried they either won't do anything, or will fall off and be a hassle. Plus, they don't do anything to seal gaps between the panels. Can you put weatherstripping in the cracks?
I was looking at this kit. For $120, that's a lot of money for a few sq ft of thin fiberglass, and goes part of the way towards a new insulated door.
This one costs about the same
NASA TECH White Reflective Foam Core 2 Car Garage Door Insulation Kit 18FT (WIDE) x 8FT (HIGH) R Value 8.0 Made in USA New and Improved Heavy Duty Double Sided Tape (ALSO FITS 18X7)
https://www.amazon.com/dp/B074LR5QF5/?tag=atomicindus08-20
pcmeiners
"I was looking at this kit. For $120, that's a lot of money for a few sq ft of thin fiberglass, and goes part of the way towards a new insulated door."
Also you need to have the same type door for it to work, look at video. Better to go the extra mile toward a decent door. Also if you present door does not seal pretty much air tight, your better off putting $120 into air seals.
NASA tech
R Value 8.0 ? Extremely difficult to believe anywhere near this R value.
Home depot, more believable.....
