Garage Door Insulation
intrepid
ON
I would like to add insulation to my 9' x 7' steel garage door. I am in Southern Ontario where we still get -25 degree C winter nights and 35 degree C summer scorchers. The door faces the south so in the summer the garage gets very hot. What is the most economical but efficient material to use? I have just under 2 inches on space from the door to the brackets. I have been looking at a product called HD 160 Isolofoam. It is 1 7/8 " thick. If I do go with some kind of foam board what should I be looking for? ie reflective on one side etc. Thanks for the help.
black2002ls
Caddo Mills, TX
I picked up a couple of the foil/bubble wrap type insulation kits on Amazon last year and did my door (16') and it made a significant difference, though, I am in North Texas so we do not see many days that are below 15-20 degrees F. I would probably use one of those kits as a nase /reflective layer, and the layer the foam board on top of it. If need be, you could fashion some retainers for the board from metal strap.
Sent from my SM-G973U using Tapatalk
NUTTSGT
Northern Central Ohio
On my old wood doors, I screwed 1/2" polyiso foil faced on them.
Are the doors you have right now, just steel or are they insulated ? You may need to adjust the spring tension after adding insulation.
A picture would help.
bradpac
Central TX
Get rigid insulation that is polyiso based, foil faced would probably be the best finish. The R value on polyiso versus styrofoam is a lot greater. You can find it pretty easy at most commercial building supply. ABC Supply down here has it in stock, not sure what you guys have up north.
I
intrepid
ON
The doors are not insulated presently. I have read on a few places that polyiso doesn't suit our northern climate well. It is good for heat but breaks down below 50 F. I am not sure I will adjust the spring tension myself as I have heard what those springs can do if you don't know what you are doing (and I dont). If I can only get foil on one side should it face the door or the inside of the garage? I appreciate everyone's help.
