Chief
I was running 4 flourescent fixures in the garage. 2 T8's and 2 T5's. Each fixture has 2 bulbs. My Genie Pro Screw Drive opener worked fine. I added 1 more T5 Fixure with two bulbs and now my openers only work when the remote is directly beneath the opener. I made the sure the antena on the unit is facing down, but still it has no range. I heard that flourescent fixtures could lead to interference and diminished range.
With the lights off, the range is still horrible. However, when i turn off the breaker that controls the lights, the range of the remotes is back to normal.
Any suggestions for a fix? Is there anything I can insulate/shield? The things that confuses me, is i have read that flourescents can cause interference, if that is the case why does my garagage remote have such short range even when the lights are not on. It appears the current in the lines, not the flourecents are causing the problem.
Thanks
Thanks
