Steve from Socal
Garage Door guru
Anyone a garage door pro, I have a unique door counterbalance that I would like to go over. It is NOT an overhead door it is a ramp on the back of a trailer. It is heavy 500lbs and it has 105 degrees of travel. Due to physical constraints it also has cable pulleys to redirect the torsion shaft assembly below the door.
To clarify the above, the door is 10' high, 8' wide and the pivot location is 114". The door frame has pulleys at 120" that route the cables down the door frame, the shaft is under the floor below the door frame.
I talked to a few door companies that kinda sorta understand the issue, none have suggested using high lift drums however, the door from full open 105 degrees to about 70 is much closer to what a high lift door would be than a regular drum on a regular door track.
Steve
Steve
