The better the vaccume in the bulb the longer it will burn. There have been bulbs that have burned for 50 or more years.
This is all nuts. Bulbs aren't vaccumed any more anyway. They mostly have argon inside.
Yes, carbon bulbs from Edison's time are still burning. No, it is not a conspiracy. The added cost of electricity to run such bulbs makes them an awful choice for any application other than mood lighting. When it comes to incandescent bulbs, bulbs that burn out in under 1000 hours is actually the better side of the compromise.
Will try a appliance bulb when I get home.
Appliance bulbs are not what you want. Appliance bulbs have a higher wattage in a smaller capsule.
If you want to use an incandescent bulb, get either a rough-duty bulb (which usually has a silicone skin on the glass to prevent shattering), or a fan bulb. They are designed to run just a little bit cooler by using thicker, but longer filaments with extra support wires. This greatly reduces the watt/lumen efficiency, but makes the bulb last longer.
Personally, I've had the best luck with the curlicue fluorescents. Be sure to get the instant start ones rated to start at -20F. They make ones that fit in the same space as a 60W bulb nowadays, and they are much more vibration resistant.
