Garage door opener light bulbs?
1982fxr
Phoenix
This will be my first time buying door opener light bulbs, both went out within about a month of each other. It's a Chamberlain Whisper Drive.
I was just going to see what's in it now and try to get those. Thought I'd ask though, any particular readily available bulbs better than others?
I work next to a home depot if that's a good supplier?
Bucko
What type of bulbs did you have in it, interesting they went out so soon. Typically LED is a no-no due to possible issues with the remote opener interference. I know Genie makes (or sells with their name on it) a LED bulb that works with openers but they are not cheap.
Ray-CA
San Diego CA
I typically use appliance style bulbs as they tend to be a little bit sturdier and vibration resistant.
1982fxr
Phoenix
They were years old. Haven't taken them out yet to see what they are.
AffableCurmudgeon
Triad Area NC
I use regular LED medium base bulbs. Haven’t changed them in over 4 years when I took out CFLs and put in LEDs. No interference, no issues with either kind. 4 cars with Homelink, 2 wireless keypads, 2 wired wall panels. Never have had any issues with LEDs, not had any issues with CFLs. CFLs came on dim but that is their normal behavior.
MeentSS02
Dayton, OH
Single data point: I've been using LED bulbs in both of my low rent, chain drive Overhead Door brand openers for ~10 years. I've never personally had an issue, and both bulbs still work to this day (as I'd expect).
They were standard Cree 60W replacement, E26 base bulbs from Home Depot (i.e. nothing fancy).
BillK
Beautiful Southern Maryland
I also have a single LED in mine. Just stay away from the "no name" leds and you will probably be fine. I prefer GE and WalMart has them.
If you want to stick with incandescent see if you can find some "rough service" bulbs for drop lights.
Mr_fixit
Rustylvania
I use a screw in handi plug ( screw in socket adapter) and then use a 2 bulb 4' fixture. I'm getting old and want to see.
Bekeart
Far Westen Kentucky
I remember reading that "rough service" bulbs were suggested for garage door openers to withstand the vibrations.
Same bulbs, same reason that were recommended for Drop/Trouble light use.
This was from the pre LED days when we used the "hot filament incandescent" bulbs.
Unlike standard LED bulbs, GE Garage Door Opener LED bulbs are specifically designed not to interfere with garage door opener signals.
Recently I replaced the "hot filament incandescent" bulbs in garage door opener with common LED lamps and did not have any problem.
Was not even aware of the special Garage Door Opener variety.
With Lowe's price being $20.98 for two bulbs, I would suggest trying a common bargain no name LED and see if they work.
I like that idea. Lowe's recently had these on sale. I replaced aged ailing fluorescent fixtures.
The shop is now much brighter, wish i was ...
Half-fast eddie
Virginia
I use a compact fluorescent, no problems. Not a lot of light, but enough to keep from stumbling around as i find the light switch.
neverdone
PA
Cheap LEDs are the issue. I don’t remember the exact standard, (maybe FCC?), but bulbs that meet that standard are ok for no interference. If the bulbs don’t have it, they are suspect to cause the interference.
mikedodge
If you stick with normal bulbs but the rough use kind like Some one else said. Normal ones don't last too long with the vibrations.
Ours is long over due for bulbs they've been out for years so I might try led's.
AffableCurmudgeon
Triad Area NC
I have about a 2 year old Chamberlain and LED's don't work in mine.
I bet that your problem is that the metal (hot contact) tab at the bottom of the bulb socket is not making contact with the metal (hot) terminal on the center of the bulb base. Some LEDs have shorter bases and they don’t make contact with socket middle tab. Easy to fix - unplug your garage door opener from power, remove the bulb from the socket, use a screwdriver or needle nose pliers to lift up the hot contact tab in the middle of the bulb socket. Plug the opener back in and try an LED bulb. It should now work. By lifting the socket tab slightly, the shorter bulb base would be able to make proper contact.
Unplug or cut power to the opener before you touch that metal tab.
Badgerstate
Columbus, OH
Just make sure you get bulbs that are made for garage door openers. Some will cause electrical interference and cause issues with the remote control.
Innovate1
I would try LED bulbs as others have suggested. If you have trouble I would try another brand. Or you can go old style incandescent. They make rough service bulbs as others have noted. Some of them are rated for 130V which makes them run slightly lower temp at 120V so should last longer and take the vibration better. Not sure how available they are.
joseywales
Southeastern, PA
If you don’t feel like you’re getting enough light through the Chamberlain cover, you can go with a higher wattage bulb than is recommended. Once the heat burns completely through the cover, melting a nice sized hole, the light shines through better. Ask me how I know…
PoorUB
Fargo, ND
I few years back I was tired of replacing bulbs in the door opener. I screwed a flood light fixture to the ceiling and ran the wires to the door opener and cut into the light circuit.
