I built my 30x36 garage back in 2006, I have 2, 9X8 doors plus a man door.
Up til now I have been the "garage door opener". but the strip of grass between the house and garage gets quite muddy, last fall's dig-up to bury a gas line and last week's till-up and grass replant doesn't help. I want to be able to enter/exit the garage thru the overhead doors so I do not have to go down the side of the garage when it's muddy or snow packed by the man door.
have had a couple of brand new openers in the attic now for too long.
They are both Chamberlain 1/2 HP chain drive "Security+" but not the same model as each other. I bought them at 2 different times, 2 different places.
The 1st one I got at an estate sale, I guess the seller died before he could get the opener installed, it sat around a while new in the box before the estate sale.
the 2nd one I got from a small hardware chain, box was full of dust and quite faded from being in stock so long. They had 2 and I thought about buying both that they had but I thought they were the same as the one I had at home so I figured there was no reason... the hardware store one was also not the "latest model" either. The newer ones have more of a "aero" design, rounded corners on the motorhousing, the 2 that I have are both square corners and an older looking "Chamberlain" logo...
Well they are not the same. I went and bought 2, 8' extension kits from Menards since these openers were designed for 7' tall doors.
I went to put them up yesterday and then discovered a big difference in them when I opened the boxes.
I 1st was going to put up the auction one. I opened it all up and then opened the extension kit, just to find out that the auction sourced opener is a T rail setup and the extension kit was a square tube design.
so I opened the hardware store one and found that it is a sq. tube design, so I had at least 1 usable opener.
The motor assy looks the same between them.
I found the part number for the extension for the T rail in its instruction manual. I then looked online and found that the extension rail kit for the T rail is discontinued. Great.
There is a rail kit on CL right now, not that expensive, not far away that looks to have the trolley kit and everything included, looks to be a square rail setup. IF I cold use a square rail on the T rail motor, that would solve my problem. Can I?
OR, does anyone know where I can get the T rail style 8' door extension kit? (found 2 part numbers, either 1704 CB or 7704 CB) The extension kit I have for the square rail style rail is 7708 CB
My other choice is to buy another newer model opener that I can use the square style rail extension kit with and sell/trade the T rail style opener to someone that has a "standard" 7' tall door....
It's a garage.... I do not care if both of my openers match, as long as they work. I mean they can't be seen from the road! so who else would know?
If one breaks down the road I'm not gonna buy 2 new openers to replace them, just gonna replace the one that dies at that time.... (even though the ones I have are 15-20 years old they are brand new so I am hoping that will be a long time off, anyhow LOL)
