air cooled
Hi,
I am building a pole barn in the Spring of 2016 (I'll start a new thread for that) and am in the planning stages.
72' X 42' with 15' high walls.
The building would fit best on my property if the 42' endwall faced the driveway. I could turn the whole building 90 degrees but it would cut off the bottom of my property a bit and require more fill.
The garage will be mainly used for hobby car and truck restoration with vehicle storage for future projects as well.
My current plan is to put both a 14'h X 12'w and a 12'h X 10'w overhead door in the endwall.
The larger 14X12 door is for general barn access and the 12X10 door is just for the 2-post lift.
I have included a diagram of the idea but have a few questions:
1- I put both overhead doors close together to give me more storage along the walls but I wonder if they are too close together (4' between doors)?
2- Should the lift be placed farther into the building from the 12X10 door so I could get a vehicle out that door if the bigger 14X12 door was blocked. Doing so might give me less storage area however. I will use high-lift overhead door tracks to keep the tracks out of the way of a truck on the lift.
3- Perhaps I should shift both doors to the North (in the direction of the smaller 12X10 door) and use the Southern wall for more storage.
Shifting both doors 3' to the North would give me 5' around a vehicle on the lift and 11' on the South wall to park cars
4- I currently don't have plans to put another overhead door in the barn because I would have to bring in a lot of fill to make this a drive through barn.
Any suggestions / experience would be appreciated.
Brian
Brian
