Sometimes, for no apparent reason, the transmitter/receiver code on the opener gets out of sequence. The fix is to reprogram your remotes. If you have lost your opener instructions you can find remote reprograming instructions at your manufacure's web site or elswhere on line.
On my Sears opener, there's a "lockout" button on the wall control. If you press that button, none of the remotes work. It can be a bit puzzling if you hit that button by accident. Do you have anything like that?
All three remotes won't stop working at the same time, its on the the garage door opener end of things, the receiver etc. not working. Does it still open and close from the wired button?
Is the light flashing on the wall button? You may need to push the learn button located up on the main unit and reprogram each remote. Some of the older green learn buttons will lose their memory with a power surge or outage. You just push the learn button one time and the remote 3 times or until the door starts moving.
