Garage Door Screen
krueges3
Minnesota
I was curious, does anyone here have a garage door screen? Mine is 16x9 so might need to make my own but was curious as to peoples thoughts that have them?
TT_Vert
Wauconda, IL.
This is what I went with with two 18x8s. Made by Universal screens. Powered and wireless controller. Also have it working w/ google assistant to open/close them. Not cheap but very nice.
Screens
HotrodHR
North Alabama
OK, for my old shop I did make my own screen... The shop had a roll up door that was about 18 feet wide and 14 feet high (commercial type building).
I picked up a roll of screen material from Lowes, 8' x 25'. Yes, not the full height but opening the door up to 8 feet provided enough ventilation. I ran duct tape along the edges of three sides on front and back of the material to create a hem. I rolled the screen up on the 25' side, raised the door about chest high and clipped one edge to the bottom of the door with spring clamps.
I raised the door open to about 8 feet, leaving a few inches laying on the floor. I used some scrap 2 x 4s to hold the bottom down. I adjusted the screen left and right to have some extra material on each side. I trimmed off about 8 feet on the long side, duct taped the cut side like the others. I added several Velcro strips on each side of the screen (adhesive backed) and on the door jamb. I just rolled the screen up from the floor side up to the bottom of the door and secured when not in use with bungee straps.
The excess screen material was used to make a screen for the walk out door on the opposite side of the shop. Overall this worked well to,keep the bugs out and provide some cross ventilation.
One more tip, I used a lot of those insect coils that you light that seemed to help too.
casmurbax
Wilton, NY
Here is a company that was recommended https://www.garagedoorscreens.com/
in this thread: https://www.garagejournal.com/forum/showthread.php?t=442542&showall=1
Screens
That is rather appealing TT_Vert. I also like what I see inside. Is it possible to share video or pictures of the inside installation?
Thanks
John
TT_Vert
Wauconda, IL.
Thanks
John
Sure, what all would you like to see? You see nothing from inside as I have tracks surface mounted to the jamb. You can opt to have the tracks flush if you are doing a new install or want to redo your jambs. With the horsehear bottom threshold no mosquitoes are going to find their way in here. I have the switch in a 3 gang box by the door into garage from house. I rarely use it as I use google assistant to open/close it most times. They are not hardwired and use a plug. I just ran an outlet to where I needed it but it does come w/ a good 14' of wire but the AC cable is replaceable at the motor which is very nice.
Dave
TT_Vert
Wauconda, IL.
Actually not too bad. I came to find out later I could have probably had them installed at this same price. $2,297 each plus $75 ea. handling and $615 shipping (for both). For both I paid 5,359 shipped. Install wasn't bad at all.
Dave
Kenstone1
I had this 3 panel double door screen in Florida.
Designed/built/installed by a local guy.
He installed longer tracks (and door closer rail) for the garage door to open it further behind the corners at the top.
Another track for the screen was installed under the door track horizontals with a flipper/track switch so the screen door used the garage door vertical track when down.
The screen opener was along 1 side outside of the track.
It worked a hoot and it had shade/privacy screen that you could not see thru.
It had switches to avoid trying to lower both garage door/screen door together.
Sorry only pic I have of it, and the guy was dodging the Hurricane install/standards/specs back then and maybe out of business by now.
I found out about that hurricane **** when I tried to buy a top garage door panel with windows to install myself.
No door company would sell me the panel or come to install it.
When I called the door companies about this they had me walk out/check my garage door for a Hurricane compliance sticker, once I told them I had that sticker, they told me the law prohibits them from altering it and could only "repair" it. :wtf:
Mattlt
MN
I went a different direction. Bought a Stihl backpack blower / fogger, and fog my yard with Talstar every few weeks. Then you can at least be outside. Makes a big difference.
aggie113
San Antonio, TX
I too have found fogging as a good solution to mosquitoes. I think it helps that the area around the house/garage is enough for me to reach with the fogger that it gets about any nearby mosquito that might be interested in biting me.
