Garage Door Size
shocksystems
Ipswich, MA USA
I am having a garage built and need to make a decision about the garage door size. The builder says that 9' is the standard size. I have an existing garage underneath my split level house and the doors are just under 9', I think they are too narrow.
The garage will be 20 feet wide, 37 feet long and have 16 foot high walls (for a lift).
What garage door size do people recommend?
Thanks!
Jim
Charles (in GA)
50 mi south of Atlanta
For a single door, 10 ft minimum. For a building of this size, I'd go 12 ft wide and 12 ft high (or more). You never know what you might want to put in there. I have a 12w x 14h door and love it. I also have a 10x10 roll up, and it is functional but I wouldn't want it as the only door.
Charles
timc
Miramichi, New Brunswick Canada
Go with the biggest door you can afford - you won't regret it down the road. I built a garage last year and the difference in price between a 10' wide door and 12' wide door was about $120 so I put in the 12' doors.
With that high of a ceiling I would go with a 12' or 14' high door if you ever plan on bringing in anything other then a passenger vehicle.
CJseven
Southeast Missouri
I would have to agree with the others, Go as big as you can. I have a 12Hx14w and a 10X10 next to each other and I like the big door a lot better. the only thing is you will need a commercial opener if you go automatic but they really aren't that bad on price for the quality. Or at least they weren't when I checked last.
NHCharger
New Hampshire
I've been building houses since 1984. Back then 8' was standard. Now 9' is standard, but as you noted by the time you trim it out it is a little less than 9'.
What side of the garage is your door going on?
For a work shop area a bigger door is always better. When i bought my 18' flatbed trailer I wanted to seal the wood deck ( it was March and I needed heat). I didn't have my shop built yet so I had to back it into the attached garage with the 9' doors. I had less than 2" clearance on each side.
