Garage door specialists! I need more clearance!
sherrod624
Sims, NC
Just installed lights in my basement shop and I need about 1/2" for the door to clear them. Is this a simple fix or should I look another fixture?
sherrod624
Sims, NC
These are LEDs. I guess I'll have to look a lower profile for those 2 fixtures
CJ7VFR
Central New Jersey
Will the door clear the fixtures if your remove the diffusers? Or would the bulbs still be in the way? Some people use LED fixtures in their garages that don't have diffusers in them.
That is kind of ghetto, but it's free.
Jim
jetnow1
CT.
Or just make a recess in the ceiling, or use retrofit pot lights where the garage doors are in the way.
CJ7VFR
Central New Jersey
...I may try and drop the rear of track first
Thanks for the help you guys
That is probably the best bet. And, in the Garage Journal way, you would not be replacing two lights, but you would be ADDING two lights somewhere else in your garage!! Which is always a good thing!
Jim
CraigStu
Blacksburg, Va
Depending which way the trusses run, could you remove a piece of the drywall and screw them directly to the trusses?
sherrod624
Sims, NC
It's in a basement shop with living space above it. 5/8" sheetrock by code. And I haven't passed the final yet so I don't think the inspector would let it role
sherrod624
Sims, NC
Jim
I'll surely put them somewhere useful. i'll have to get a pick of the shop now, I have plenty of light!
