I was quoted $300 to fix a door that was only 13 months old. One of the cable reels wasn't tightened properly, and slipped over time. My door opener tried to tear the door off the wall because of the way it was jacked around.
Home builder blamed me for the garage door install.
Screw you I say.
Studry step ladder - Check
2 pieces of steel rod - Check
Being very careful, not standing/looking right at the thing while I tightened it - Check
If you can't do something without being careful, and understand that if the bar isn't fitting tight, it might slip out with a LOT of force, then don't do it. If you are careful, make sure the rod fits in the roller correctly, go slowly and methodically, then it's not that big of a deal.
Then again, most of you guys with 2000sq foot showrooms have enough $$ to pay someone, in which case I would too
Door works perfect, and I kept $300 in my pocket. I can't believe companies charge that much to fix a door...I'm in the wrong biz
