Garage door window privacy
Dustball
Hudson, WI
Does anyone have any pictures (especially of a Clopay garage door with their OEM frosted windows) that they could post? I haven't been able to find anything online.
Clopay GD2SU with the obscured insulated glass option.
Brian_WK
NE South Dakota
We just did white 6 mill plastic with 4 rare earth magnets hot glued in the corners let's light in. Can't see in and move out if the way if you want to see out. Obviously only works on steel doors unless you attach something to the aluminum / insulation door.
Brian
4xdog
Santa Fe, NM
you can also get the frosted window stuff in a spray can. works great. just did a bunch of windows on a buddies house/garage and was quick, easy, and cannot tell it is from a spray can...available at box stores or amazon, krylon or rustoleum make it.
This is what I'm going to do as the restoration of the six-light double-hung wooden sash windows (three of 'em) in my garage get completed. A lot easier than cutting thirty six small pieces of film.
Group B
CT
I just used the frosted spray in a can. It's far easier than cutting film. Just clean the windows cut a window the size of your door window out of a piece of cardboard to make a movable mask, and spray. Two coats a few mins apart and the whole door was done in less than 15 mins. If you don't like it, it scrapes off. I couldn't even see any overspray. If you scratch it, just respray the scratch. Fills in nicely. Now nobody can see in and it still lets a lot of light in.
e015475
Show Low and Mesa Arizona
I made overlay panels from opaque acrylic sheet I bought from a local plastic sheet supplier and cut on a table saw. The doors to my shop are 8' french doors with clear glass to the outside and the acrylic overlay on the inside - I had curtains and mini-blinds and I like the overlay best. Here's what it looks like at night-
View media item 53666Has the additional benefit of having saved me a couple of times from breaking the glass in the door. They're held in with some screws driven into the plastic window molding. Have to take them down every 4-5 years to clean out the bugs and dust
vettex2
Northern Ca.
I got mine at Home Depot :beer:
chamoisfive
NewZealand
One wonders what activity in a garage requires that kind of privacy?
I have a nosy nieghbour that love to snoop & tell what he sees. . . . . . When I'm pottering around in the evening i prefer not to have the two-level houses nearby peering in. My business is my business, just that and I value my privacy
Bigrob88
The Gila film at Home Depot is what I used on our bathroom window that is shin high, faces the street, and clear as day :) even with blinds you could get a show from the street
its just like working with window tint so it can be frustrating depending on how much you have worked with tint
tried a cheaper film before that and it bubbled and peeled and acted just like a cheap walmart window film would
toolmiser
La Crosse, WI
I myself have had "neighbors" tell me that they were over, and looked in the garage window and saw the vehicle was gone. I think from a security point that makes it real bad, I know people could look in from one of the sidewall windows, but they are a little higher, and you would have to be more deliberate. A glass person told me to be careful about putting tints on the inside of "thermopane" windows, as it could heat up the inside of the two panes of glass and cause the seal to break.
