I want to run a couple of 20A circuits in the garage. My house has the old 100A Zinsco stype main panel with only 2 slots left. The zinsco breakers are $$ so I was thinking about installing a sub-panel in the garage. I noticed there's a 30A dual breaker (2-pole?) in the main panel that was used for a jacuzzi at one time but no longer used. I'm trying to come up with a way to use that for the sub-panel. For the sub-panel I don't need much, just a $30 4 slot panel will do. Assuming I will not be using more than 30A at a time I should be OK using the existing 30A breaker as the main feed to the sub-panel. But if I did the 30A breaker will (should
) trip and I should be fine?
The only things I have that require 20A circuits are my small welder, smallish compressor and the mid-rise lift. None of which I'll operate at the same time.
The other option is to run two new 20A circuits from the main panel and be done with it. Is there anyway to reuse the 30A 2-pole breaker for this or do I have to buy 2 20A zinsco breakers?
) trip and I should be fine?The only things I have that require 20A circuits are my small welder, smallish compressor and the mid-rise lift. None of which I'll operate at the same time.
