Ok, another question,I have my power supply up to the garage,it is running in a 2" pvc conduit to an LB,I haven't drilled my hole into the garage yet but once drilled, can I just stub a small 2" piece of conduit into the garage from the LB then route my wires to the panel? Or do I have to attach another LB and up to the panel keeping it in conduit to the panel?
Also, my copper ground wire from the grounding rods,can I run this in the same 2" conduit as my feed ?
Thanks!
Thanks!
