I am building a new 32x40 garage (see here), and, I have a bit of a problem with the concrete at the overhead doors. The pitch is not sufficient for drainage, and there is a very slight low spot 8-30 inches inside the door, so when it rains I get puddles just inside the doors (when they are closed).
The overall ("macro") pitch is good. It is nearly flat for the back 20', then pitched about 4-5" over the next 20'. It is just right at the door opening that there is a slight lip or uptick that extends outside the door the 8 or so inches to the edge of the slab.
The contractor is willing to try and work with me to fix it. He was going to grind it down, but seeing how much it would need (1/8"-1/4" over both 10' wide openings), he suggested a threshold. While this might help, I am concerned that it would never seal well enough to keep water out. I told him he could try it on one door and if it didn't work we could look for a plan B. Is it reasonable to think a big concrete grinder could work in this situation? What would you suggest?
