Desert rider
For those with their workshop in the garage, how do you deal with the slope of the floor?
If I were building a new garage I would not slope the garage floor and would not put a floor drain in it .
But it depends on what you use it for.
I wanted it to be as close to level for chassis work and fab.
You would appreciate the Auburn Cord Duesenberg Automobile Museum. They have the original granite blocks for chassis setups for the cars in the museum. (The museum is the old car factory.) The things are immobile and perfectly level and true. The floor around them is just whatever it is...
Thats my kind of nerdy stuff right there. I bet that was an expensive piece of stone and setup!
Dave Morgan has tried to get race tracks to install flat and level pads that guys can use for chassis setup, but very few have such a location. Up north the frost makes such a pad too expensive for the local tracks to even think about.
I use lag bolts in the bottom of the legs on any wood framed work bench. Adjust as necessary.
My Dad did the same for all of his model railroad support benches, that is where I learned to do it, 60 years ago.
Same concept for metal, just use a bolt or adjustable foot pad instead.
Mine was just done this way.
Poured level using a laser, no drain, cut control joints with a machine burnished finish.
I wanted it to be as close to level for chassis work and fab. I will never wash a car in the shop, and the one time every few years I need to bring a snow covered car inside I will just use a big squeegee to clean it up.
