Garage Flooring Options Galore
Dakrisht
Hi all - new to the forum and new to this project so would appreciate some insight from the pros.
Have a 2-car garage that has a relatively fresh, clean concrete slab (12-months old, no oil, contaminants, coating, just raw).
I’m looking for the best DIY option for some sort of coating or paint without spending $1600+ on a professional epoxy job.
After a good amount of research, here’s what I’m seeing.
1. Use a HD consumer grade concrete paint such as the Behr Granite Grip product.
Pros: $60 for a gallon. Textured.
Cons: Probably won’t last, will chip and peel from tires, heat.
2. Use a HD consumer trade 1-part epoxy paint from Behr.
Pros: None
Cons: Reviews say it’s just garbage
3. Use a higher quality “paint” from RustBullet. Their DuraGrade Concrete line, they claim it’s a polyurethane (I think) and has excellent adhesion to conference, doesn’t require etching, etc.
Pros: Seems like a well reviewed high quality coating.
Cons: Higher end ($200 for the gallon and $200 for the clear coat).
4. Use a professional grade epoxy kit from epoxy-coat.com. Found about it on this forum. Seems like a commercial grade epoxy kit.
Cons: $1,000 so might as well go for a pro job which is a touch higher at $1,600.
5. Use an epoxy kit from RustOleum.
Cons: seems like garbage
My goal is to just make the garage look better, so ideally, after a power wash, degrease and extra dry concrete slab, I’d love to just paint the concrete with 2-layers of a high quality paint, add some flakes and call it a day.
Any suggestions on what to do / what not to do?
Thanks in advance!
D
Dakrisht
This is a great, simple and elegant look.
Not sure if Ghostshield will actually make raw concrete look like this. But the raw, grey, concrete with a subtle sheen on top is gorgeous.
Would much rather a look like this vs. the usual epoxy + flakes that’s so common.
D
Dakrisht
DuraGrade seems like a solid paint-only approach and Ballistix over it but… DuraGrade is $500 or so all-in.
Might as well go Epoxy at that price point from one of the forum links mentioned above.
Should I just stain it to give it that cloudy / textured look and then do Ballistix on top?
Garage Flooring
Grand Junction, CO
I would highly advise against doing options 1 & 2
Option 3: We sued to sell their product and it works fine if you ignore the part about no prep needed. My experience has been that the way they word things if there is a warranty issue they blame it on the prep.
The epoxy coat makes a great product
Option 5 seems to work wonders for some and not for others. I have not tried it
Personally:
Polyurea kit from us, Legacy or Armorpoxy
If not that a good DUY system **** as Legacy or our TrueLock
D
Dakrisht
Personally:
Awesome thanks for the insight.
Your kits do look good - I assume your polyurea kits is basically an epoxy-like coating with flakes (at least the look and feel)?
What about this Ghostshield situation? Good idea to stain it so it’s gets a cloudy / textured look and then just Ghostshield to seal it?
Issues with slipperiness of the floor? satin or semi gloss finish?
Happy to do business with your company
Garage Flooring
Grand Junction, CO
Ghostshield is just a sealer. 0 aesthetic value.
Polyurea is an outstanding alternative to epoxy. The kits include the base coat, the clear coat and the flake. The GJ7 coupon code gives members 7% off although it is 10% on a sale set to expire in a couple of hours
Armorpoxy
Take a look at the kits from the vendors here, you'll get great support. We also are selling a new technology called Ballistix which gives even better performance then urethanes or polyaspartics, and requires very little prep. Can be applied as a clear standalone coating or as an incredible topcoat over other coatings.
