Hello all
Some great build threads and knowledge base I am hoping to tap into here.
New to home ownership and excited for this adventure but I have a few questions.
My house has a 3 car attached garage that I am hoping to heat with a modine hot dog 60000 btu heater. The garage has insulated walls and the ceiling finished with the exception of the first 3 ceiling joists. I am not sure why this was left open but I plan to insulate this area. Tonight poking around in the attic I find that the area above the garage that is insulated is connected to the house attic and has blown in insulation. It is sitting on the drywall ceiling and there does not appear to be a moisture barrier between the drywall and blown in insulation. Is this common?
I am wondering if I am heading towards moisture problems.
Goal for heated garage is to leave around 45 degrees F and raise the temp when I want to work out there. I am in MN. Garage door will be opened 4x a day and there are no floor drains. Two cars will be bringing in snow and the third will be stored for the winter.
Thanks in advance for any thoughts.
