Garage Heater Power
Lance101
Northern Indiana
Planning on putting up a natural gas unit most likely the Big Maxx or such. 45000 btu heater and was wondering how I can go about wiring it. My panel is currently full because the builder obviously cheaped out on the panel and was wondering if it would be a no no to just tap into one of the outlets in the garage. I have a gfi about 8 foot away on the wall. Not sure if a sub panel would be viable in my predicament. I'll post a picture of my box and then you can be the judge on what my best option would be. Trying to keep this the cheapest way possible. Thanks!
Jlbc212
Northeast MA
You could replace the panel with one with more breaker slots. Panels are not that expensive.
The cheap way would be to run a separate line from the heater back to the panel and piggy back onto one of the breakers. Gas heaters don't draw much electricity. Use 14/2 wire and piggy back onto a 15 amp breaker.
CoopVA
Virginia
Do not piggy back a breaker... Replace the panel.
CNGsaves
KS and OK
+1 to Replace Panel with larger subpanel as looks like you just have bare studs with insulation only (ie no sheetrock or wall covering yet).
You do know that GJers have lots of goodies in garage . . .
. . . 240v compressor, 240v welder, and maybe a 240v tablesaw or two . . . . ;) . . . .
. . . . you WILL need a bigger box !!! :D
Jarcese
Boston, MA
How much power does it use? I can't find any electrical specs on Big Maxx or Modine. They just say 115v. I'm about to buy a Modine(which I've heard is the only way to go) and I had pretty much the same question. Will that size run on a 15 amp circuit? If so then you shouldn't bother with the panel unless you want to. The GFCI should be enough, but where are the electrical specs on these things? I'd like to know what kind of work I'm in for before I order one.
CoopVA
Virginia
A gas fueled unit probably only needs 15a for startup and control. They may even be able to plug into an existing outlet.
Stuart in MN
Minneapolis
Gas unit heaters generally have pretty low electrical requirements (maybe 3 amps or so, depending on make, model and size) so you should be able to use the receptacle circuit for power.
Most breakers arent rated for 2 wires so u would either have to splice 2 wires into one to connect upto an existing breaker or tap off one of the existing outlets!
RickP
Annapolis, MD
You might be able to wire the heater with a 6' power cord (depending on the heater model) and just plug it into a receptacle. That would be your easiest option.
Kevin C
Portland OR
Algoma56
Sault Ste. Marie, ON
We used some mini's to get 2 breakers in one slot similar to picture above. Can't remember the actual name for them, but my electrician friend supplied and installed them. That way you can get a dedicated breaker for your heating system, which is required here.
Jlbc212
Northeast MA
Modine HD45 heater draws 3.7 amps according to their installation specs.
D45
NW INDIANA
I would just buy dual breaker, like shown above
No need to buy a new larger panel and rewire everything
CoopVA
Virginia
I agree. I deal in commercial work, and didn't even know these were available...
Learn something new everyday...
L
Lance101
Northern Indiana
Thanks for the replies! That additional breaker may be my best bet unless I can get away using a wall receptacle. I'm going to be building my garage at my house that I buy next year so I don't want to replace the whole box. I just need heat now for my winter garage hobbies and to keep it at around 50 when I'm not in there.
