Hey Guys,
I’ve been working on heating my garage for some time and I cannot decide on the best way forward. Let me know if you can help. Here is the situation:
The garage; 22x24 double attached. Spray foam insulated walls and roof (~R20). I am located in Manitoba (design temp of -10°F). Temp is held around 50°F. Used as shop and to warm cars. Currently using 4800W construction heater with success. Have used only radiant convection oil heater in shoulder seasons. I turn up the heat to work once per week and the big overhead door is opened a couple times a day minimum. Ice/snow melt from the vehicles pools in two low spots in front of the doors.Also to note, the cost of natural gas is about half of electricity per unit of heat output.
The problem; the construction heater should only be used temporarily so I’m looking for options as to my permanent solution. What makes this situation unique is that I have already ran tubing for radiant heat…..but due to a disagreement with the contractor I wasn’t able to get in to insulate under the slab or at the slab edge. I realize now that this was a major oversight, but I need to move forward and work with what I have. I’ve done the heat loss calcs and I estimate a little over 30% more cost versus forced air options to heat the space.
Here are the solutions that I’ve come to (feel free to add any others):
1. Forced Air Natural Gas (ie. Scrap the in floor tubing) – unit heater or even IR
2. Radiant with Electric Boiler
3. Radiant with Gas Boiler
4. Combo Electric Radiant/Forced Air NG
*Tankless and standard HWT options for radiant have come on and off the table. One major drawback to the standard tank is that garage space is at a premium, not to mention the equipment isn’t exactly designed for this application….but costs are good, though.
Option 1 is the least expensive for unit, install and operation. Also, recovery is pretty good. The drawbacks are noise and comfort. Ceiling mount won’t help much with pooling water.
Option 2 is a little higher cost for components and install than a unit heater. Comfort is high, will help with pooling water, no noise. Recovery/Ramp will likely be an issue especially with insulation losses. Also, this is by far the most expensive to operate.
Option 3 is about half of the operational costs of option 2, but the wall mounted boiler is around 3 times the cost. Comfort is high, will help with pooling water, no noise. Recovery/Ramp will likely be an issue especially with insulation losses. (I realize that a standard floor mounted boiler is about half the cost of a wall mounted version, but floor space is precious. It is still worth considering though.)
Option 4; Until recently this was seen as a ridiculous option, but when presented with the costs of the wall mounted gas boiler it became more viable. Some electric costs are mitigated. Recovery/Ramp is improved. Less noise than unit heater only. Comfort of radiant heat. Some assistance with water pooling.
Hopefully I’ve presented my situation. I’m sorry for the novel, I just wanted to make sure all the details were out there.
Thanks in advance for your time and thoughts.
