Garage Heating
Outback2013
New Brunswick, Canada
Radiant Floor Heating
I am building a garage 26 x 40. Will be heating with a radiant floor system. I will have to heat with electricity, at 10.25/kw. There is no gas in this area. I have read about heat pump style hot water tanks, boilers, standard hot water tanks and quite frankly a bit lost as to which one is the best fit, generally speaking.
Presently our home has an 800 sq ft addition which I heat the basement with radiant floor heating. This system has 2 zones heated by a 40 gal hot water tank. It has worked seamlessly for 24 years. I also have a 40 gal domestic HWT. I am wondering if I install an 'indirect heating system' using an electric boiler or heat pump hybrid heater to heat our domestic water and then by use of a heat exchanger run two circuits to the in floor systems, via pumps to their tanks or directly to the floor.
So, bottom line, I have to heat my garage and may decide to consolidate the 3 hot water systems. Has anyone had any similar experience with the above?
kabinenroller
S.E. Wisconsin USA
Why don't you consider an on demand hot water heater? Do you have access to propane? I would think propane is less expensive to use as a fuel.
In my old shop I first used an electric 40 gallon water heater to the floor, it had a difficult time recovering during cold weather. I then changed to a 40 gallon propane unit and that solved the recovery problem.
I sold that property.
In my new shop I use a propane on demand heater to heat the floor, it works very well, I also find it economical and basicly trouble free. I think an electric unit would be less cost effective. Insulation is the key to having a hydronic system that works well.
