Garage Heating
CB427
Ellington CT
Building an insulated 28 X 36 X 9' ceiling garage, 2" X 6" walls, R-19 walls R-30 ceiling, with 2 10' wide & 9' high insulated garage doors. Desire is to install a propane heater for occasional garage use with temp set at 60 degrees. Any recommendations on brand of propane heater and size ?
thanks
dlcwent
Member Emeritus
coastal maine
Goodman offers some good products and are reasonable priced.
www.goodmanmfg.com
I've been using one for a few years. Originally purchased as a secondary heat source, I found myself using it as my primary heat source last year. It's been a very reliable unit.
73RR
Blank Email
Central Ory-Gun
I just looked at the Alpine website and played with their size 'estimator'....it failed to consider that it was -9° here this morning.....
Forgot to mention that a stainless steel heat exchanger usually adds 50% to the life span for not a lot of extra money.
C
CB427
Ellington CT
Noticed the estimator only asks for square footage, without cubic footage to take into consideration a high ceiling.
Showkey
"MEMBER EMERITUS"
Wausau WI
77rr.......here another ball park estimator .....fine tune the guess up or down based on ceiling height, insulation value and climate.
[/URL][/IMG]
Just replaced a Lennox 65k btu unit that had a circuit board melt down. Replaced it with a 45k btu Beacon Morris because it was in stock and on sale, fit the ball park estimates. 900 sq. Ft. 9' ceilings and well insulated. It works just fine and we are expecting -15* F tonight. I keep the shop at 50-60* all the time.
The Lennox was 15 years old, getting rusty and the board and upgrade kit was over 50% of the new unit.
Autorotica
SE Pa
[/URL][/IMG]
Wow, heat 4K square feet with 120K unit heater? That must be designed for something that will be heated all the time...
What about something heated only when being worked in? Sporadically.
Chris
matt_i
One of the assumptions is 60F temp rise over ambient/exterior.
So if its 10F outside you should be able to hold 70F inside constantly....no real calculation for internal gradients but just a "box" analysis of heat in vs heat out.
Some oversize is nice because it heats rapidly. But, at the same time, the 60F temp rise may not be needed. I'm usually happy with a 50-60F interior with a 20F exterior.
6768rogues
Western NY
My personal preference is Reznor. I have 40x60 and a 36x48 buildings in western NY that are insulated but not quite up to your specs. They both have 100,000 BTU hanging Reznor units and they heat well. I keep them at about 50 degrees but when I want to warm them up to work in them they heat quickly.
James-W
Southeastern Wisconsin
I have a 24X36 garage with an 8 ft ceiling. I have R-19 in the walls and R-30 in the ceiling. I am using a Hot Dawg natural gas 60,000btu heater and it works wonderful. But keep in mind that I keep the temperature at 50F when I am not working out there so when I decide to do some work out there and I turn up the heat, it warms up pretty fast. Since you don't plan on heating it all the time, a 60,000 btu heater will take longer to raise the temperature up to a comfortable level. But 60,000 btu's seems to be the right size for the insulation you have and for the size of the building.
