olds70supreme
- Joined
- Mar 7, 2008
- Messages
- 697
My 3 car attached garage was sheetrocked before I moved in. Unfortunately, this was done without insulating the walls. Only the wall that is common with the house is insulated. This common wall is only on the two stall part of the garage, so the third stall has no insulation at the front at all. Is blow-in insulation my only option? If so, what should I know before starting? The only way I can see to do it is to cut an access hole (3-4 inches in diam.) at the top of the wall between every stud. Is there a better way to do it?
Thanks for any advice. I am hoping to do this before the end of September (I live in SE MN).
