New construction. 900 sq ft. with 10.5 ft ceilings. Insulated panels with R-24 walls and R-38 ceilings. Eastern Wa.
I'm going with a Reznor 30,000 btu direct vent heater. Combustion air is sourced from outside the garage.
The area will be kept at maybe 35 degrees in the winter, and heated on demand when I'm out there working on a project.
I may have screwed up with the direct vent heater. With snow and such on the daily driver, there will be moisture in the garage. I'll go with waterproof primer on the drywall, and that should help a bit.
But how do I deal with the condensation when I heat up the garage? There's got to be a way to get rid of it. Other than opening up a window and running the Reznor.
Thanks in advance.
Thanks in advance.
