driftpin
As mentioned, some good here, some bad.
All the respondents who said, "get the local Zoning Code, familiarize yourself w/it, and be sure of your zoning classification," I agree with. Anyone who said, "sneak it in," that is a BIG NO!
I worked in planning and zoning, I wrote zoning determination letters, and did plans review for people trying to do something like you're proposing. I do not hold-out hopes for you getting what you want, with your present level of knowledge.
If the zoning says, "no accessory uses w/o a residential dwelling," probably the only way to get by that is with a variance. 'Self-imposed hardships' or wanting to build an accessory use, a garage, in a residentially-zoned district, on a vacant lot is likely not going to be approved.
Building a minimum-sized dwelling allowed by code, with a maximum-sized accessory use, legally allowed, is going to be the path to getting approval. There may be consideration for an attached multi-car garage and a detached accessory use such as a garage or hobby storage, or whatever terminology is locally-used. Another member mentioned the possibility of calling it 'tractor storage.' Study the local ordinances to see where an interpretation might help in what is legally permitted.
Bear in-mind that if you're attempting to build in an area where the zoning density is 6 dwelling units/acre, meaning 6 D.U./net acre, or ~35,000 sq. ft. instead of a gross acre of 43,560 sq. ft. where the plat is surrendering 8,560 sq. ft. per gross acre for roadway rights of way, utilities, flood control, public safety & etc., the mean size of each lot is ~5,000 sq. ft. When you take into account the maximum permissible plot coverage you are not speaking of a very large development allowable. Perhaps the best answer is to find a plot where your intended use is not subjected to such onerous regulation.
Members mentioned the 'AG' use, Agricultural zoning requires (usually) larger plots than single family residential (SFR) plots do. However, the allowance for out-buildings is often more-generous, and sometimes may require rudimentary permitting.
Whatever you do, don't go into a project thinking that you're going to skirt the zoning code and the building code, and will do whatever usage you want, versus whatever usage is allowed if the two are in-conflict. If you want to have a place to work on cars or motorcycles, repairing them for 'a few customers a week,' you will soon run-into the local jurisdictional officials' enforcement efforts if you're attempting to operate a business not-allowed in that zoning district. All it takes is one disgruntled neighbor to register a complaint or an enforcement officer, or the building official to shut-down such an operation. When fines begin, they can continue to accrue until the building official or other enforcement official is satisfied the violation has stopped and the land parcel is now in full compliance.
As to that, above, don't post advertising online or on your property, "Al's Car Repairs, Best in Alabama!" or anything similar.
The two places where your local government posts its zoning code are
The best advice I can give apart from the above points, is that you should consider the use of a professional planner, land development specialist, or land use attorney who does business in the jurisdiction where you hope to purchase land. They are familiar with the local code and the people who write it, interpret it and enforce it.
- American Legal Publishing
- Municode
