mobetta
That will not work properly. A GFCI needs all three wires connected to it, with white and black from the panel going to the "LINE" side connections (it will be marked that way) ground to the ground screw, and all downstream receptacles black and white come off of the opposite set of connections, with the ground crimp-bonded to the end of the ground wire on the GFCI.
The lack of ground on the GFCI is probably what trips it.
not to confuse the OP, but I dont think this is correct. AFAIK, a GFCI is the only way to put a "grounded" outlet in place of a polarized outlet(2 prong, no ground) ONLY if you use the "No Equipment Ground" sticker. so the ground wire not being attached is most likely NOT the reason for the OP's problems.
