Garage paint scheme
Gunner54
New garage build (38' D x 32' W x 14' H) is primed and ready for paint.2026-08-19_16-54-42_702.jpeg
AI is suggesting this as a paint scheme:
Thoughts or comments welcome.
Thanks
Stuart in MN
Minneapolis
I agree that while black ceilings are popular right now but they aren't the best for lighting, you need to factor that in when choosing fixtures. Also, a 14' ceiling is on the low side for using high bay light fixtures, I'd think about using regular fixtures - otherwise the light distribution won't be very even and you'll get 'hot spots' under each light.
Shiftless
East Bay SFO
Light will be from 9 × 150W LED high-bay fixtures.
Did you do a lighting plan for that or just pick the brightest fixtures out there and go with 3x3?
Is that going to be just for parking? Mostly a man lounge space party room? Mechanical work being done regularly?
I agree with Stuart that the high bay bulbs at that level will result in bright spots which are much less comfortable to live with compared to more even lighting achieved with more fixtures of lower lumen levels.
G
Gunner54
My electrician recommended wide angle hi bay fixtures to eliminate hot spots. They will be on 3 individual row dimmer switches.
Garage will be storage (BendPak HD-9XW / 220V lift going in shortly), some light mechanical work.
I agree with the others - I'd re-think that black ceiling.
Too late, first coat of flat black was installed this morning...
Shiftless
East Bay SFO
Let me add on to my previous post and say that you don’t necessarily need more than 9 fixtures but instead of having a one foot diameter fixture yielding 15,000 or more lumens you can have a bigger fixture like an edge lit flat panel that is 2x4 feet giving off the same amount of light (measured in lumens) but more spread out.
Nice soft lighting like you see outside in a bright overcast day.
My 20x20 garage is primarily lit by 9 four foot twin tube LED fixtures.
Craig Balzer
Colorado Springs
The main bay of my Hobby Shop has 14' ceilings. I used these fixtures. Great light; no hot spots
  • 7x HB 150001 50
  • LED: 18” x 30” 150 Watts
  • 18,500 Lumens
  • 5,000° K
  • $150 each (in 2019)
These are dimmable LEDs - requires a special switch and wiring. In hindsight, I woulda just got standard lamps. I always have the dimmable switch at the highest level anyway.
This photo shows two of the three rows of light fixtures. I am standing under the 16' wide garage door; there are two more lamps above my head.
Also - note the white ceiling and walls. With the light grey floor covering, I have lots of reflected light.
Shiftless
East Bay SFO
G
Gunner54
If you’re looking for input and suggestions, next time give us more than 3 hours from initial question to going ahead with what was apparently already scheduled,
Had you taken the time to actually read my original post, you’d have noticed I asked for thoughts or comments... not suggestions or input. Thank you for your comment.
Shiftless
East Bay SFO
After working on cars for 40 years, I can tell you, I've never worked in a shop that I thought needed a dimmer for the lights.
I can see if a garage did double duty as a lounge, that dimmers might be needed to better see the big screen TV for your 10 friends to watch the Super Bowl etc.
Quickstep192
When I was much, much younger, I made kitchen cabinets for my first house. I wanted to use hardwood plywood for the carcasses, but economics dictated melamine flake board.
Wow did that ever work out!
The white melamine made everything in the cabinet easier to see and find.
Since then, If it’s going in a place where seeing is important, it white, white and white. (Until something lighter comes along : )
Dagny
Northern Wi.
I have wired many farm shops but am doing my first black ceiling right now. I need to take my flashlight out to look in the sidebins on my lift.
Sorry it's dumb.
I always recommend some type of linear highbay the bigger the better. but most of the time ufo's go in they are cheap,hot and harsh but it's not my money.
joebass3
I wanted a bit of color (and a lot of light), so I went for light gray, red stripe, medium gray. With a gray urethane floor and drop ceiling with restaurant kitchen washable tiles and drop in LED panels. No shadows in my shop!
I did a very similar paint scheme in my garage. I went with 4 high bay lights and am pretty happy with the amount of light. Only change I would make is to the floor. Flakes are far from ideal. I'm constantly searching for anything small that I drop.
johnre
Portland, OR
Garage and shop walls, and even ceilings, get bumped into a lot - people, equipment, stuff leaned up on them, etc. And in my book they then get patched and touched up, so it can all look like new again.
The best color to take a touch up and not show it is white. I use a flat white for walls and ceiling, and a semi gloss white for wood trim, for ease of cleaning.
DaveAndStuff
Bangkok
Had you already painted it I would say it looks great. But since you haven't, I will say I think the black ceiling looks awful.
And I agree with everyone else about the light.
My favorite shop color combo is:
White ceiling
Medium dark grey bottom 4' of the wall
Mint (or any light color you like) from the grey to the ceiling
drmarkr
Tucson
Great minds think alike...
drmarkr
Tucson
To the OP. Your storage room will appear smaller, and will be dramatically darker with the flat black ceiling.
Yankeefarmer
Connecticut
How many GJ’ers’ shops look as clean and neat as those pictured in this thread? No disrespect toward any who posted photos here, but they all look to me like a newly set up shop, not one in which work is regularly performed on multiple projects. Workbenches are too clear, etc.
G
Gunner54
I wouldn’t do black ceilings. ***** too much light. Shows dust like a diamond in a goats a$$
Love the analogy!!
So after reading all the "comments" which I do appreciate, paralysis by analysis set in .... and I'm changing the ceiling to Trout Grey 2124-20 plus extra $$$!!
OccupantRJ
Eastern North Carolina
I think avoiding a black ceiling is a wise choice in a working shop. Being able to see details properly is usually a major concern as you age in life. Visual improvements become more important than a cool look in daily activities.
DaChev
I think even dark grey is an improvement. I have dark grey semi-gloss and the only place I am lacking light is the under cars on the lift.
If you think black shows dust, white will show way more. that is ultimately why I went for an alternate.
