Garage Pit Removal
Ben Hall
Hi,
Currently have a pit in the floor of the garage. It looks like it was built in the 1950 or 60's.
I want to fill it in and remove it.
Anyone got any tips or advise.
Dan in Pasadena
Pasadena, CA
Call your local concrete ready mix company and order single sack slurry. It is what’s used to backfill around buried utilities and provide the equivalent of 95% recompaction of the native soil - IF you were using soil. But you don’t have to place slurry in lifts and have it mechanically compacted and tested.
Actually, you could use a lesser slurry up til the last 3 feet below grade to accomplish the equivalent of 90% compaction and THEN use a stronger slurry to make 95%. But in such a small pit it’s unnecessary. Then place 2500 psi concrete the last 4” or the depth of your existing floor slab.
ItsNemo
Canada
Fill er' up, wacker packer the **** out of it as you go, slab on top, done.
Not much to it.
rsanter
visalia ca
Why fill,it in? Use it,for,storage and make a steel,cover.
A friend had one, he used it for steel storage. Installed racks on the side that held the steel tubing
Aberdale
I made a cover for mine. when I sweep the garage floor all the dirt gets swept into the pit. Should last my lifetime.
Hpozzuoli
Rhode Island
I wish I could find what computer the pics are on. Last year I had a customer with a pit in a garage that abutted the basement. Huge garage so instead of filling pit with cement I cut the back wall that separated the pit and basement and thru a set of stairs in it. We created a garage entrance to the basement via the pit.
That pit is a free fallout shelter, storm shelter, or root cellar. Don’t be in a rush to fill it.
NUTTSGT
Northern Central Ohio
How big is the pit ?
If you plan on ordering a load of concrete to top it off, you need to find out what their minimum load is. If the min load is 3 yards, you might as well get your money's worth and fill the majority of it with concrete.
Empty Pockets
Rural New York
While the pit may be a little unsightly, they can come in handy. I would just get/make a cover. That would much cheaper than a lift and less likely to fail.
6768rogues
Western NY
Fill it with bank run gravel or #1 crusher run in 6" lifts, compacting it between lifts.
Or fill it with flowable fill from a concrete supplier. It is a low cost cementitious material with fly ash that gets hard and does not settle but is excavatable.
Then top with concrete.
Ben Hall
Thanks for all the great replies! I will take photos tonight and post them up of what i am starting with!
casmurbax
Wilton, NY
For future people in a situation like this, you should use flowable fill, it is much better and gets you very close to 100% compaction without any manual compaction. The local concrete company would deliver it and pour it in. It fills voids nicely and when it is hard, you can still dig it with a shovel. It is essentially sand with a bit of cement.
In your current situation, you could dig down a ways, add water as they said and then compact it as best you can in 4" lifts. Most likely 4" will be fine with voids under it, but that hollow sound would drive me crazy. As Tink said, you could always pump grout in through holes when (or if) it gets a void under it. I would drill them afterwards instead of leaving access holes. Just make a designated area that you know there won't be rebar to hit with the drill.
The above was from another thread.
or perhaps you could do this instead?
