Hello fellow garage enthusiats:
I just moved into this new place and naturally i wanted to upgrade the garage . First thing on the agenda: coat the floor
So here are the results from my recent garage project. I decided to go with the UCoatIt epoxy floor coating.
Light grey base and color coat with the granite flecks. Top coat with UGloss clear coat.
I really like how it came out, i just hope it will hold up to the new england elements.
Base Coat:
Finish Coat:
Close up:
And the car that will reside there:
Next up is to paint the walls. Im thinking white egg shell walls with blue chest stripe. I may do a tri-color with two shades of blue...
Base Coat:
Finish Coat:
Close up:
IS HOT! I found that it will burn through the coatings even at bench height. I throw down a welding blanket if I am cutting under the car or near the floor where sparks will not have time to sufficiently cool down. Remember to clean up your slag and debris as soon as possible, because it is very aggressive and will scratch the coating and dull it out if walked upon.
