Above 1200 Sq/FT Garage Refurb®
Prospecter
Maine
I cut out all the squares of carpet. I used a hot glue gun to attach them to the shelves. I had to glue one to the fixed shelf which is part of the drawer.
Once that was done, I put the shelves back in.
Looks good! I also like hot glue for projects like this. Instant gratification, and easily reversed.
rharman
SoCal
For a number of years, I had a mini-fridge and microwave in my office at work. I, too, put a piece of carpet on the top, as well as between the fridge & microwave.
I'm sure you did, but for peace of mind, please tell me you cut notches in the carpet for the runners in the locker.
My OCD will rest better. :cool:
N
NUTTSGT
Northern Central Ohio
:cool:
Only in the bottom section above the drawer.
The shelves, I merely traced the shelf out, I didn't cut it to the size of the locker itself.
N
NUTTSGT
I ran (drove) to town and picked up 2 rolls of sandpaper. Unfortunately, the guy at NAPA brought out the 100 count rolls. I wanted the 25 count rolls but that's okay, I will have it for the future.
I pulled the emblems and hardware off the Snap on cabinet and started sanding.
I still have to cover this side with something.
N
NUTTSGT
Before I closed up for the night, I wiped the inside down and blasted it with some black Rust-Oleum paint. I'm not too worried about the look of the inside.
I forgot about doing the back of the cabinet last night. Since the garage was still warm at 66° this morning, I wiped the back down and gave it a coat of black.
I started a fire in the wood burner and went back in the house. I'll be back out in the garage after while.
N
NUTTSGT
It will look great. No need to worry about putting the first scratch in it. It fits in with a garage that work actually happens in. Nice work.
Honestly, it needed sand blasted to remove all the paint. The surface isn't smooth after year's of use
Doesn't really matter though, the gray paint is now drying and the wood burner is stoked up providing some nice dry warm air.
N
NUTTSGT
Did you match colors pretty close to your new boxes?
It's a Rust-Oleum gray, industrial or utility version. It's more of a dark charcoal gray whereas the US General boxes are slate gray. I think you can see a bluish tint in the right lighting.
That being said, this box will be in the addition, about 12 feet away from the US General 27" stack, so it'll be close enough. It should look good with the dark gray paint on the bottom of the walls.
I'll post up a picture of the Rust-Oleum can this weekend.
N
NUTTSGT
I like it.
No chance of it getting hit by the garage door?
I don't think so. That overhead door doesn't get opened often. Actually, none of my doors get opened and left open. It's too loud living on a state route and there's the prying eyes.
Looks great. A shame the door doesn't swing the other way.
Wish I had a good spot for a metal cabinet for chemicals.
Thanks. I considered trying to flip the door around but there's no slots for the door latch.
N
NUTTSGT
I noticed the other day that I had some build up in the black chimney pipe. After thinking about it, I don't believe I had cleaned it out. Since we had a break in the colder weather, now was the time.
After pulling the pipe apart, I checked out the horizontal section. Not bad, better than I was expecting.
N
NUTTSGT
Looks pretty clean to me. You've got good burning habits and dry wood. When my chimneys look like that, it hardly seems worth the effort. (Although it is, of course, worth the effort to be sure the chimney is clean.)
I did have it plug up one year. I didn't get to burn alot but it was a bitter cold winter and damp for us. I'm pretty sure I had a hard time getting the chimney warm that year
N
NUTTSGT
Pretty sure NuttsGT has seen his fair share of chimney fires in his line of work so not amazed he looks after his wood burner what he burns in it.
Nice job on that paint cabinet, fits right in with your new toolboxes.
Actually we haven't had a chimney fire in a few years. It doesn't seem like many people in the city are burning wood anymore.
I don't know if it's because people don't need supplemental heat or just too lazy to cut it/lack of places to cut
Johanfpa
Aberdeen Scotland
Chimney fires are on the increase here, more people are using stoves to save on using other expensive energy options. Sadly a lot don't know you have to season the wood and to check wood moisture levels from the so-called seasoned fire wood some people sell.
Ordered some fire wood this summer for a neighbour and had asked for seasoned because she needed for burning this winter. The guy said all his wood was well seasoned, but when he showed up with his tipping trailer I checked it with my moisture meter and it was just under 30%. Told him to get some from his properly seasoned pile and he came back with 17% moisture content wood saying that he had mistakenly loaded recently processed wood.
N
NUTTSGT
Fortunately, I cut at my parent's woods. I have 17 acres to choose from standing dead and what has been down a year or two. . . pre-seasoned when I cut it.
N
NUTTSGT
Started a project the other day... like a few days ago, after spending Wednesday, Thursday and Friday at work. I need to get some work done in the kitchen so I stained some bead board.
I had the issue of the previously used Minwax stain no longer available. I thought the color might match close enough. However, once I got to the end of all the pieces I realized it wasn't going to match.
N
NUTTSGT
Needless to say, I couldn't restain to make it lighter so I had to buy more headboard. After some Google Fu, I learned that Sherwin Williams owns Minwax so I stopped by the local store.
I was able to get Puritan Pine custom mixed. I went home with a quart not caring what it cost.
After buying 5 more packs of headboard, I spent some time staining all of it.
