Above 1200 Sq/FT Garage Refurb®
IONH
Central Massachusetts
Re: garage refurb
If you're going to be precise enough with the tape to have near perfect angles of the same size, that's definitely a handy piece to have around!
akdiesel
Wasilla, AK
Re: garage refurb
Nice refurbish work on the bench top, and I agree about the thinking in advance for a fabricating layout design.
My wife found some floor finish by Varathane #2300 clear gloss that apparently does not yellow and is durable. About $50 a gallon at HD.
Omphaloskeptic
Ultima Ratio, Wa.
Re: garage refurb
If the top isn't going to be exposed to constant UV, I'd opt for a 2-part bar top self-leveling product available at most BB stores. Level the top surface carefully using shims at the floor, use some wax paper covered battens for a temporary 'edge dam' and pour the mix onto the surface. Once it sets up, screw some aluminum edge moulding onto the top to finish it off. I've used the stuff in the past with good results by having a hair dryer and a straight pin handy to 'tease' any air bubbles to the surface where they were popped by the straight pin. Just my $0.02 offered as an option!
Vernmotor
Mt.vernon oh
Re: garage refurb
That looks good. I thought you had tile squares on the other top. never thought about you painting like that !
N
NUTTSGT
Northern Central Ohio
Re: garage refurb
Thanks guys. I sent an email to Minwax to see if they had any suggestions.
Bricen18
PA
Re: garage refurb
First post here
Wow What a great project, you do such great work. Well done sir!
N
NUTTSGT
Re: garage refurb
Nice! That top turned out really great. Beautiful.
Ody.
Thanks Ody, that picture still shows the white primer and not the white paint. I finished that up last night. I also got a reply back from Minwax. They suggested waiting 20-30 days before coating it with some polycrylic.
First post here
Thanks Bricen and welcome to GJ.
Wingnut65
Tampa Bay, FL
Re: garage refurb
That workbench is going to be great. I can just hear a theme song in the back ground... We can build it Better... Stronger... Faster... Oops, wrong song. But it will be nicer! :thumbup: And that grid pattern will definitely be useful.
I'd even suggest adding a power strip under one side that you can plug to a cord when needed and have a few outlets for router, circular saw, buffer, or other Tool of the Day.
Nice job at cleaning up the storage room. Those are always dreaded projects, but look great when done. Hope you took pix to recall how everything fit in there. :lol:
N
NUTTSGT
Re: garage refurb
The power strip was thought about it at one time but since I movethe table time to time, it got ruled out. My parents bought me a cord reel for Christmas which I mounted on the ceiling above the work table.
I was quite happy when I moved everything back into the back room, somehow, it all went back in better than it came out. It created some extra space that hopefully doesn't fill back up. ;)
N
NUTTSGT
Re: garage refurb
After some aggravation dealing with the beta version of PB, I got a few pictures uploaded. Although the last picture in post #1143 appears to be done, the white is primer. This is the final shot after the white paint was applied, along with a few empty rolls of tape. I'll be waiting a months and then apply a few coats of polycrylic.
A few weeks ago I tried out a product to fill in the expansion joints in the concrete floor. This was the result, showing dirt already too.
N
NUTTSGT
Re: garage refurb
In the above picture, you can see where I tried to smooth out the product I was using after I filled the joint. It resulted in smearing some of it onto the floor which needed to be cleaned off. It seemed to wipe off rather easy with lacquer thinner but that in turn removed the sealer. Oh well. . . .
Here's a closer shot of what it looks like. I'm sure some of you guys could get it smoother than I did. I merely wanted to fill the joint in so it fill with other stuff like sawdust then smolder if a welding berry rolled into it.
I liked the way it went in and thought it was going to work so I bought a few more tubes of it when I went to HD, then a few more when I made another trip. Something needed to be done about maker it easier to "finish." It was decided to mask the edges of the expansion joints with some tape which would be pulled after smoothing it with a finger.
Yes, I went through alot of masking tape this past week, 4 1/2 rolls I believe. . . . and yes my cuts are not straight, the tape exaggerates them but I cut them dry and had so much dust I literally couldn't see my chalk line. Lesson learned.
What's that ? What am I using ? I never thought you'd ask. ;)
This would be the product I'm using, Sika Concrete Fix. I found it at HD for about $6.** a tube. It claims to yield 12 linear ft at so wide/deep. I think I got about 10 linear feet out of it. It seems to be a great product but it's thick coming out like an semi-set up epoxy and not like caulk.
IONH
Re: garage refurb
Good read on the expansion joint fix Eric. Is that stuff flexible so the joints can still do their job? (expand/contract)
hpw
Re: garage refurb
flexible?? very...........some good stuff
N
NUTTSGT
Re: garage refurb
From their website.
Sikaflex® Concrete Fix
Moisture-cured, 1-component, polyurethane-based, non-sag elastomeric sealant. Meets Federal specification TT-S-00230C, Type II. Meets ASTM C-920, Type S, Grade NS.
Use
*Designed for all types of joints and cracks where maximum depth of sealant will not exceed ½ in.
*Suitable for vertical and horizontal joints; readily placeable at 40°F (4°C).
*Has many applications as an elastic sealant between materials with dissimilar coefficients of expansion.
Ideal for:
*Weatherproofing of joints,cracks and gaps in concrete, brickwork, blockwork, masonry, stucco and metal frames.
*Joints in walls, floors, balconies, around window or door frames.
*Expansion joints.
*Roofing.
Characteristics and Advantages
*High elasticity – cures to a tough, durable, flexible consistency with exceptional cut and tear-resistance.
*Stress relaxation.
*Excellent adhesion – bonds to most construction materials without a primer.
*Excellent resistance to aging, weathering.
*Non-staining.
*Urethane-based; suggested by EPA for radon reduction.
*Paintable with water-, oil- and rubber-based paints.
*Capable of ±25% joint movement.
Not trying to sound like a Sikaflex commericail but I figured straight from the source is the best answer. :beer:
SpeedinLemon
North Texas
Re: garage refurb
Hey Nutts. Great job on the workbench table. Those rabbets and cross bracing look really solid. Is it as sturdy as it looks? I've drawn up about 10 different versions of a work table / assembly table / table saw outfeed table. Dont have the final design still, but I think I'll steal your table top design. Keep it going! :thumbup:
Chris.
N
NUTTSGT
Re: garage refurb
Chris.
It seems to be stable. I haven't done much on it yet. I'm trying not to screw it up before I get a coat of polycrylic on it.
It can't be any less stable than the old top and it was good to go.
sreno
Eastern Townships, Qc. Ca.
Re: garage refurb
From their website.
Use: *Designed for all types of joints and cracks where maximum depth of sealant will not exceed ½ in.
Ideal for: *Weatherproofing of joints,cracks and gaps in concrete, brickwork, blockwork, masonry, stucco and metal frames.
*Expansion joints. *Roofing. Characteristics and Advantages
*Stress relaxation.
*Non-staining.
I'll take a case if you can deliver by Friday. :lol:
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Re: garage refurb
Make sure you post up how the tubes of Sikaflex works out. Your cracks look like the once in my garage, all the way through. I need to get mine filled in as I'm getting tired of sucking dirt out of them all the time.
N
NUTTSGT
Re: garage refurb
Haha. Funny thing is, I was telling a buddy of mine about the stuff. He just put up anew addition for his shop and paint booth. He just gave me that look and was like " do you think I have time for that?" :lol:
N
NUTTSGT
Re: garage refurb
So far,so good.Even though it hasn't been in for long, I have swept over it and it didn't pull out. I'm planning on changing the trans fluid in the truck next week. I'm sure I'll spill some so I will see how it reacts to that.
On a side note, I have applied three coats of Minwax polycrylic to the worktable top. It has a few bubbles in it but hey, it's a worktable. ;)
Rag Roc
Central Florida
Re: garage refurb
FWIW we use a self leveling epoxy at work that gets air in it when mixing. After we apply it, we make a few passes with a heat gun from 12" away and the bubbles rise and disappear.
rbtaylor14
NW Iowa
Re: garage refurb
Nice work Eric. I just read through your whole project. 3hrs worth of reading. I am impressed with you work.
N
NUTTSGT
Re: garage refurb
Picked up a new tool for the garage, an older Cman drill press. It needs some TLC but it going to serve me well for future projects. The smaller bench top Skil made it's way to the other side of the garage to get used for wood projects now.
N
NUTTSGT
Re: garage refurb
Nice score on the Drill Press. Are you going to race your Mustang this year?
Thanks, the drill press came from over in your area, IIRC. Akron-Canton. I doubt the Mustang will get out this year, hopefully, I'm going to get some things lined up and finished so I can get back on it next year.
04fivefour
Perry Township, OH
Re: garage refurb
Man I have sat here and read every page of this thread and i am impressed. I am a fellow ford guy and mustang guy and ohioan. You are extremely creative with some of these ideas you have. I am particularly impressed with your masonry work. That is the one thing that i have personally never tried. Did you have an experienced concrete finisher help laying it? I am wanting to redo my driveway and I know that i can bust it up and lay it out myself but from everything ive read its best to have someone experienced finish it. Sorry to hijack just extremely impressed with your craftsmanship.
N
NUTTSGT
Re: garage refurb
Thank you for the compliments.
The block work for the garage shed wall and chimney I did myself with no help. The garage floor, I laid out but had help from family members in the construction trade, I did get my hands dirty and gained experience on it.
The apron in front of the garage was done be me and a friend. He has some concrete experience from years of farm work and such. I did a majority of the finish work though.
Simple flatwork isn't that hard and all it takes is some experience under your belt. I'd start with something small like a sidewalk or section of it. You can practice putting a nice finish on it or a broom finish which is quite forgiving.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Re: garage refurb
Eric.....that's not my area. I'm 83 miles southwest of you in Urbana. :beer:
N
NUTTSGT
Re: garage refurb
LOL. I thought you were on the other side of the state. :dunno: Hell, you're closer than I thought. :lol_hitti
Heck, you can hit up both Columbus and Dayton CL. Even a trip up to the Lima area wouldn't be bad on 75.
JC23
Northcoast
Re: garage refurb
Ha ha. I wuz just thinking of your place and wondering if you had posted lately. Now I know.
Always a good read, Eric.
N
NUTTSGT
Re: garage refurb
Thanks JC, just not much going on. I'd love to have some great projects going but it's not really in the works right now. I did put up a retaining wall along the drive way (by the house) I think I might have a few pictures but I'll have to grab the camera.
N
NUTTSGT
Re: garage refurb
I uploaded a few pics of what I have been working on, it's not so much in the garage but behind or in front of the house garage.
Several years ago, I "cheaply" put in a retaining wall just to separate the yard from the driveway. I basically stacked some field stone that were here when we bought the place. Once I put the sidewalk in to the front porch, we added some mulch and a few flowers. It ended up being me the one that pulled the weeds out, so last year I made a decision.
After pulling a few tips from JimVonBaden 's thread on the paver driveway, thanks Jim along with everybody else that offered up information. Jim's thread:
http://www.garagejournal.com/forum/showthread.php?t=145450
I chose to use one course of concrete block as the foundation, on top of stone and tamped screenings. While the project was building in my head, I decided to make it two block high. Since this is along the driveway, I didn't want to under mine the wall if we chose to do anything different for a driveway . . . asphalt or concrete.
Here's the the second course started. I'm not sure if it made a difference but I ran a piece of rebar down each hole.
While I realize it's not straight, it is just the base course and I had an issue with some tree roots kicking my ****.
Once the blocks were filled and tamped, I put a string up for the retaining wall blocks and began it lay them down. This was the end result.
N
NUTTSGT
Re: garage refurb
After the wall was done, I went back to the garage and added an area in front of the shed door. I used some bricks my parents had come across many years ago. They were part of a sidewalk that they took out.
