Mike0105
Hi Everyone,
I moved into my house a couple of years back and the one part of the house that was in serious neglect was the garage. To date I haven't really done much but I'd at least like to put together a project plan and start to tackle some of the bigger projects. I've broken the garage into three main sections and wanted some advice on what to do first and opinions as I'm not even sure what to do with some of the issues I've identified.
Garage Floor
As you can see in the pictures the floor has taken a beating. It's to the point now where just sweeping it is bringing concrete dust up from the areas that are no longer smooth. My end result is some sort of epoxy floor so what's my best option here? Is this too far gone where the floor needs to be pulled out and repaired? Can this just be grinder smooth and epoxy applied over the new smooth surface?
Garage Walls
I have some peeling paint, cracks everywhere, holes here and there. In general the drywall is in poor condition and in opening up one of the holes it isn't insulated. I'm not planning on heating or cooling the garage but would like it insulated in case I want to work on a car in the winter, have a project etc. Does it make sense to pull the drywall down, insulate and then re-drywall? Am I better off just putting some holes in the walls and putting in blown insulation and then sanding the peeling paint, cracks etc and skim coating? I don't need anything perfect in the end but want something that looks nice
Lighting
I want lots of lights
The garage has two windows and a door so it does get some natural light but I like to detail cars and the more light the better. Recommendations on products or set ups would be appreciated.
Lastly, what order do I do all this in? This will be a piecemeal type project and I'm not sure whether to start with the floor or the drywall piece first.
Thanks for the help! I've attached a few pictures of the floor and a section of the wall.
Mike
Garage Floor
Garage Walls
Lighting
Mike
