nolimits76
I agree w/ the thought that you use what you have and will find a way to make it work. Obviously if you can afford it, we would all recommend you go bigger.
Outside of that I would seriously consider dimensions of the cars you plan on working on and then figure out how you will need to layout your lifts, workbenches, compressors, etc. to make all that happen for you.
I was contemplating an old Scout or Bronco project myself. They aren't very big. It's been a year or so since I pulled the specs (found old diagrams on Bronco forum) but they were roughly 6' wide x 14.5' long or thereabouts. Compare this to my Dodge Ram 4x4 that is approximately 7' wide x 19.5' long. My Challenger was similar in width but shorter.
In an ideal world I'd make the shop so you can work on a full size crew cab truck and then it would fit any of the smaller stuff.
Using the width of the Ram, I'd figure it this way....
<--3'--><---7' Ram ---><---4'---><---7' Ram---><--3'-->
That gives you 3' on each side and 4' between the vehicles, for a total of 24' INSIDE dimensions. Be specific about this being INSIDE dimensions -- many builders will make them outside dimensions, which then gives you something like 23' and some change of usable space.
For a working garage, the above seems too narrow to me. I'd go 26' or 28' if money allows.
