Hello all, planning to install a sub panel in my attached garage. A couple quick questions. I purchased a Square D Main lug, 8 space 16 circuit.
Does this main lug need a disconnect in the garage? I've read on some places you need one, some other forums, you don't. I live in MN, and again it's an attached garage.
Also, what would be the best wire to use for this run? My main panel is only about a 8' wire run to where my main lug will be. It will all be ran inside, and within walls. I'm going to put a 60 amp breaker in the main panel. I'm assuming 6-3 with a ground NM, but I've read that's only good to 55amps.
Thank you.
Thank you.
