mp333
OK. I have updated my original post. It was late last night when I posted....
Hope the layout pic and the pdf for panel's break down is help full. I also have two other sub panels. One next to the main panel and the one for the pool #2 is on the opposite end of the house.
I am looking to install a 80A sub panel in the attached 3 car garage to power a 240v Heater, Compressor, 110VAC lift, EV charger and couple 20A outlets.
The Panel would be fed from the main panel with Copper Romex NM AWG-4/3 & AWG-8 ground cable.
I have couple questions that I am not finding answers to....
The sub panel is going in the finished attached garage. Above the garage is the master bedroom. I have no access above the garage. I am looking to surface mount the sub panel for obvious reasons. I do not want to cut the dry wall as the branch circuit will be going across three bays.
The two studs are just for illustration in the pic.
Do I need to mount a plywood behind the panel? If yes, does it need to be painted?
If I mount on to plywood (orange) the sub panel outlined in yellow would be mounted in the center.
If I do not need the plywood. I can only get the right side of the (gray) sub panel screwed on to the stud#2 as shown in the pic. The left side would not have any stud to secure. How do you secure the left side of the panel? Can you the butterfly bolt anchor type on the left side of the panel. The panel would be secure with two butterfly bolt anchor and the two screws into the stud on the right side.
Also what is the minimum distance you can have between the edge of the panel and window. What is the code?
Also the generator feed is not wired in. I have a spot for it on the main panel. I plan to do that with an interlock switch.
Thank you
Thank you
