Hi, I just bought a Hobart 210 welder and figured I was good on 115v but then when I decided to wire in a 50 Amp plug I started looking around abit.
My panel goes back on about 60 ft of wire, all looking to be Romex 10/2, to a 40 Amp breaker in my main panel in my house. This is in metal conduit for most of what I can see but I have found direct buried romex to my shed (which I disconnected and cut out) so this may be partially too. I'll have to dig after I power it down. I'm sure a shovel into that would be exciting.
I need to run a new service but there is so much bad or conflicting info out there and I'm having a hard time figuring it out.
My plan is to run new wire in pvc conduit, end to end (60 - 65 ft), with #4 to support a 100A. I have a 230 welder, a 5hp- 230 air compressor and plan to add a split AC/HP in a few months after i finish out the detached garage.
I'm not sure what wire type or what grounding I need to add. Sounds like 2 rods, 8 ft apart into the ground bus, separate from the neutral (which I don't have now).
Any help is appreciated!
